Differential lock rear end
Not sure if this is the right place or not, but... in order to have diff lock on a super gt can a guy swap a jd430 rear end in and also get high and low range?
Thanks, David |
It's too wide for the frame. Plus, the stance is wider too.
If the 430 rear is as expensive as everything else for those it might cost you an arm and a leg to get one.
I like to keep em running and work them. 1872 (I call her Vera), 782D, 154 Loboy (w/tiller, 3260 deck, and front blade), 3-1650s, 2-1000s, 149, 147, 106, 1810, Farmall Cub, Haban sickle bar (not mounted), No. 2 trailer and several parts tractors. |
Is there a way to get/have diff lock?
Only other choice is trying to get one out of a 3000 series to work. But I don't know if the frame width is the same or not.
If your super has independent rear brakes, what do you need a diff lock for? |
I have heard of installing shims on the side gears to make it much "tighter" and for it to act like a posi.... I'm thinking brass shims would be the best.
Thoughts? |
I wouldn't. That will make it impossible to steer.
shims
Hello, I shim the fine splines in our pullers. About .012 on each side, doesn't leave much room for the axle clips. I deburr the oil grooves in the side gears. I got the steel shims from McMaster Carr, some 10's and 2's. Still turns just fine. Mike
Yeah, but do you do anything other than pull with it?
