Members in Chesterfield VA area ?
Are there any members in the Chesterfield/ Richmond VA area, that are with knowledgeable on the 1872's ?
Thank you Steve C |
What is your problem Steve? Some of us may be able to help you fix it.
Welcome to Only Cub Cadets.
Well I have 2 issues, 1st the Haban deck 60" and them the motor/govoner.
The deck appears to be bent but not sure where and the motor does not respond to a load and when it does it runs outta control. I have followed the settings found doing searches on here for the 18 magnum and no luck, I am not sure if there is internal damage or not. I bought this used a couple of months ago for $600.00 thinking there can't be to much wrong but I believe this thing is possesed by it's former owner who was the original purchaser and passed away. |
Can you get pictures of the deck? Also, have you made sure the engine has good oil and plugs?
'74 IHCC 108 - 38A, supersteer axle '75 IHCC 1000 - 44A, Sears wheel weights '87 CC 1872 and 1811 - Haban, 44C '96 CC 1863 - 54GT '79 JD 400 - 60" deck "Projects" '67 123, '65 102, '71 126 |
http://www.onlycubcadets.net/forum/f...er=desc&page=3 Need some more info on the deck problem before I can offer a guess. Pics would help.
