Kubota WG600 to overhaul or not
I have a new to me 2182 with the WG600 engine that smokes terribly 5-10 seconds after startup. Compression @#1 = 105 #2 105 #3 120. Starts right up idles smoothly. Rebuild kit run 650+ that I've found so far. Oil pressure test tomorrow. Anyone have any similar experiences? I could rebuild or replace with a diesel version for about the same money.
Compression is too high for it to be a bad cylinder, unless it has a broken oil ring. Change the oil, run it a while and see if it goes away. Might clear up. If not, pull the head and rebuild it. With those compression numbers, it may only need valve seals. It's likely been overheated and killed the seals.
This is from the WG600 service manual. Looks like your engine is in need of a rebuild.
