Broke a leg...
Hey guys haven't posted in a while and figured this was worthy of sharing. Been using the 1772 a lot lately. Just built a new garage and have had a lot of dirt to move around among other loader tasks. I was backing up a dirt pile when I got stuck. I went and extended the hoe to help pull myself out. Then I heard a snap! And saw my fender sitting on the tire. Broke the axle clean off. I was actually relieved that it was just the axle to be honest. But then I was trying to figure out how to get the tractor out of the dirt. Wound up using the backhoe as a crutch and limped out till I could pick it up with the case 580ck.
127 - 48'' deck + tiller. 1512- 46" GT deck & bagger 1872- 60" Haban 1772 turbo diesel- Iron rear + KW loader + backhoe + 3 point. Case 580CK Ford 850 International TD-8E |
Ouch! What does that hoe weigh? Do you have ballast in the rear tires? The manual for my Kubota says not to run fluid in the tires with the backhoe on. It has do do with the fluid in the tires taking away most of the cushion from air in the tires.
Adam 1964 Model 100 w/ K301 12hp and custom hydraulics 1972 Model 149 turned 129 w/ K301 12hp, triple hydraulics, 66 series clone |
That is the problem with abusing a garden tractor, and that is exactly why
the design was never intended to put a loader and a back hoe on them. They make a scut which is more robust or as you know/have a TLB. Sorry for your breakdown, glad nobody was hurt. I bet it failed at the weak point where the brake drum is welded to the axle shaft. |
I am running fluid in the tires, probably about 80% full. The backhoe only goes on when I need it otherwise its off and a 3 point /200lb count weight takes its place. It broke just about 1/2 inch from the weld. Looks to have twisted right off. Got a replacement on the way. I was looking at upgrading to the 30mm shafts. Anyone ever do that? I understand the axle tubes need to be machined to fit the larger bearings. Anything else?
Hope it's just the axle. Last time I busted an axle on one of my trucks it took out the spindle along the way.
I really hope not.
