Old 03-03-2013, 10:59 PM
Plowboy1086's Avatar
Plowboy1086 Plowboy1086 is offline
Default Painting my Cub
What primer should i use a light or dark one? An what grit sand paper should i use
Bi-Polar Plowboy Plowboy X Press
Old 03-03-2013, 11:22 PM
Default painting my cub
What grit sand paper should i use and a light or darker primer. An what grit should i use once its primmered
Old 03-04-2013, 09:24 PM
CadetTY's Avatar
CadetTY CadetTY is offline
I use 80 on a d.a then 180 on d.a prime then sand with 400 by hand and on a d.a. i use grey primer
882 diesel, x3 ih 582, 73 124, x2 82 seriers pullers, 1686 16hp puller
Old 03-04-2013, 09:39 PM
vartz04 vartz04 is offline
I've always used the red oxide color primer on any equipment type stuff I've painted. Seems to work fine for me. My dad did a whole ford 640 only using the red oxide primer in rattle cans and a spray gun. Valspar makes it
Cub 104 Refurbed Sprinig of 2013
Aftermarket headlights, 3 point, Brinly Adapter, Spring Assist, 42" IH Blade, 42" Mower Deck, 42" Craftsman Grader Blade, 10" Brinly Plow, 6-12 ags and 22x9.50 turfs
Old 03-05-2013, 01:14 PM
rushlow122's Avatar
rushlow122 rushlow122 is offline
I used a medium primer on a john deere that i had and i started out at 400 grit and went up from there but i stoped at 1000grit
Old 03-05-2013, 06:47 PM
What should i use to get the original paint off im using a wire wheel on the frame
Old 03-05-2013, 06:49 PM
Cadetty what isd.a
Old 03-05-2013, 06:56 PM
jkier's Avatar
jkier jkier is offline
Cadetty what isd.a
Pretty sure he means a Dual Action sander
106 Needs a clutch-------107 (Lent to my brother)
123 w/hydro lift & qa36--126 w/creeper and lift
127 restored--------------129 50" mowin machine
129 w/hydro lift-----------147 plow horse w/tiller
149 auction score---------782 KT17SII
Old 03-05-2013, 10:44 PM
CadetTY's Avatar
I work in a body shop and paint cars for a living.... 1000 gritt is way to fine for the paint to bight into. 800 is the highest id go. D.a dual action sander. Wire wheel works bt sandbladting is fast and gets rid of rust easily
