need help!!!!
I have the LTX1046. I'm having a hard time getting my deck level. I get it close but it seems to run out of adjustment. I'm on a level surface when I measure. U guys got any ideas. The mower is a year old.
Check for bent blades
Can you give more infor on
runs out of adjustment Sometimes the large nut will move after you pull the wrench off it to tighten the inner one. |
K and the side were the adjustment is it needs to move down and the adjustment is all the way down.
I'm mean the deck has to go up on one side.
Ill bet the whole unit is loose, or broken. Ive only seen a hand full that were broken, most are loose or missing a bolt from vibration or not tight from the factory.
I think I have to do a 1045 tomorrow, if I get it on the bench Ill do a few pics to what I mean. Chancces are if a bolt or a pice is missing cub wont cover it as the deck vibrates. |
Check my deck yesterday and the way I do it is with a set of calipers , set the blades east/west then measure the side opposite the adjustment then compare it to the side with the adjusting bolt.
If the side with the bolt needs to move undo the top lock nut and wind bottom nut anticlockwise to lower or clockwise to raise that side , relock top nut , measure again and you may have to repeat procedure again to fine tune. Remember as you raise or lower the adjusting bolt side the other side does move fractionally in the opposite direction Also on the Cub Cadet site you should be able to download a manual that shows how to do it |
Like the guy said down under. I use 2x2 on the bench and we run 12 lbs of air in the front tires and 10 on the rear. Tire will also give you an unlevel deck. Ive seen this little nut on the back have broken weld and they wont stay level. This one is in for new drive idler, only has 34 hrs on it.
K thanks when I get a sec. I'll check it out
