What a mess!!
Buddy of mine wanted to know why his 1200 was not running right and always wanted to "run away"
I told him Nov 8th was just a few weeks away and time to elect a new governor among other things!. Don't Ya think!! Todays trivia ?? What's wrong w/the last picture? |
I'd say a new governor is in order! Looks like you got the good out of that one!
Brian April 1979 1200 Quietline 44A deck 1988 1211 customized into a 1288 with a K301AQS 38C deck and a 1864 54” deck . Snow blades 42" and 54" . Brinly disk, brinly plow a cultivator and a $5 brinly yard rake! |
Looks like it's time for a full rebuild, I can only assume that the governor in the oil pan is what broke the dipper.
Yep, it's junk.
Only thing I see in the last pic is that the head gasket was leaking..... |
Something looks weird in the valve seat area, not much sealing surface it appears.
HeliCoil sticking up by far left head bolt? Picture is fuzzy on my pc.
Queen Of The Quietlines! |
Looks like a couple of oversize bolts stuck in there.
You guys are close!
The center bolt is 5/16"??? & looks to be helicoiled, bolt was gr5, rest are OEM Head gasket looked good though it may have had some blow by and it ran good when it did run. Crank, block & valves are at the machine shop now waiting on diagnosis. |
