Blower chute crank
I have a 2082 Cub Cadet with a 45 in blower, and a cab. The chute crank is outside the cab on the left, and can't be reached from inside the cab without removing some of the cab shield. Is there an extension that I am missing or other part? I just bought this tractor, so its new to me .....thanks
I'm not sure what you're missing, maybe just a hole in the cab to insert the crank handle thru.
What does occur to me is that you might install a 12V chute actuator and then only a couple of wires need be routed into the cab to a three position toggle switch, left - off - right. I have this setup on my RAD 54" 2 stage blower and it works well. |
I am going to venture a guess, that the Cab is NOT made by Cub Cadet, perhaps a Sims Cab. With that in mind, there would be no extension from Cub Cadet to accommodate your situation. I am thinking personal engineering, fabrication, or modification is the route to pursue.
As always, pictures of your tractor would be more helpful.
