Old 03-21-2012, 08:02 PM
jeffscub's Avatar
jeffscub jeffscub is offline
Default kubota diesel to a cub
guys, i've got a chance at a kubota hst 1600 GT for a steal. i am wondering, and i've also searched on here, if that engine would be an easy shoe in for a 128??? and i know somebody will chime in and say "anything is possible". i've just got this 128 laying around not doing anything and thought that might be an interesting project. any thoughts or comments are welcome and appreciated!!!! sorry if this is posted in the wrong section. thanks jeff
'72 108 w/ 38" HIGH speed deck, '77 1200QL w/ homemade grader blade, '79 1450 44" grass tamer, '70 sears super 12 w/ 3pt , 19?? 100 w/ extra toys, 69' economy powerking 14 horse w/ FEL, 65' economy powerking w/ toys, 1982 allis chalmers 716
Jeff
Old 03-21-2012, 08:28 PM
TheSaturnV's Avatar
Well it's got the same frame as the 782D, 882 so that part should work depending on how much larger (if any) that motor is than the D600. It can hang out the open sides, but I wonder about hood and grill grill clearance. Is the original setup with front or rear radiator?
I'd be happy to do some frame/engine measurements on my 882 if you get serious and think it would help.
Old 03-21-2012, 09:40 PM
jeffscub's Avatar
it is a rear sitting radiator. it's a tiny motor, but it's a 16hp though. i'm not to familiar with the d600. i'll have to do some research on it. and yeah, i would greatly appreciate the measurements. it's probably not gonna matter, because in between work, yard work,sleep, and eating, i'll shoe horn it in someway. thank god for torches, saws, welders, lathes, and bridgeports!!!! thanks, jeff
Jeff
Old 03-21-2012, 09:46 PM
D600b info
http://ccmanuals.info/pdf/Kubota%20D...e%20Manual.pdf
Old 03-22-2012, 07:45 PM
A 128 and 882 do NOT have the same frame.
I suspect it would be a tight fit if it fits at all. The 82 series tractors have a lot more room, and it's a tight fit in there to begin with. I have seen a D600B in a QL, but it looked like getting it to fit was a nightmare.
Old 03-22-2012, 08:18 PM
TheIHMan's Avatar
TheIHMan TheIHMan is offline
Matt is right. The frame on the 82 series is flared out at the top and the diesels take up the whole area. You would have to make a whole new mounting system to be able to bolt the engine into and I'm not sure the radiator will fit either. Your best bet is to find a 82 series tractor without and engine if you really want to get this engine.
Old 03-24-2012, 11:12 PM
dkreger's Avatar
dkreger dkreger is offline
I built this one. It's a 1450 with a 722 kubota, stretched the frame about 4". I put the radiator up front and built mounts similar to the 782D.
Old 03-24-2012, 11:48 PM
TheIHMan's Avatar
Wow that looks amazing!
Old 03-25-2012, 12:14 AM
Your cub is awesome! You did an excellent job on it!
Old 03-25-2012, 01:37 AM
Well said by both of ya!
