Old 12-24-2021, 02:47 PM
Ryankve's Avatar
Ryankve Ryankve is offline
Default Cub Cadet 1650 Snow Thrower Belt Pulleys
Hello Everyone! This is my first thread on this website and I am happy to be a member.
I have recently purchased a snow thrower implement for my Cub Cadet 1650. It isn’t the exact one for the Cub, but I’ve heard of people making it work. I attached it and they pulleys do not line up. I was wondering if anyone knows of a fix. The snow thrower’s gearbox would either have to be longer, or the motor would have to sit further forwards.
I will attempt to attach pictures in order to furthermore explain the issue.
File Type: jpg B4B1618F-9E28-4365-99EE-0CF1C1D385F4.jpg (16.9 KB, 99 views)
File Type: jpg BE60DC30-97C9-47A2-91E7-8D22D39ED7D5.jpg (26.9 KB, 96 views)
CC: 1650
Old 12-26-2021, 07:33 PM
Farmall450's Avatar
Can you mount/move the snowblower in closer to the tractor with new holes/brackets?
Otherwise I think you might have to get a longer shaft for the snowblower's pulley to go on.
Old 12-28-2021, 05:46 PM
Workingstiff Workingstiff is offline
Might be cheaper/easier to fabricate a pulley with an extended collar than a new shaft. Could go either way.
'76 1200 Dad bought
'75 1200 "Twinsie" per my daughter
Old 12-28-2021, 06:02 PM
Johnd Johnd is offline
Does the unit look like it can be pushed back farther based on the cut in "U" at the rearmost point. It's hard to see in your picture. The spring bar seen just above the snow blower pulley looks bent. Pulling up on the spring bar allows the unit to move all the way into position. When the spring bar is down the blower is locked in position.
IH Cub Cadet 682
Haban snowblower attachment
Old 12-28-2021, 09:02 PM
green407's Avatar
green407 green407 is offline
bwahahahahaha, that looks familiar.
Couple years ago my brother bought a 1250 and then that winter he bought a thrower. Almost the same set up as you have. That thrower is a Haban designed for use on the cub 82 series. I'll try and take a few photo's of the modifications I made on my brothers unit and post them.
128 X 2, 129, 149, 1450 x 2
Old 12-29-2021, 10:10 AM
finsruskw finsruskw is online now
You need a QA42A for that unit
Problem solved
