Old 05-15-2022, 06:18 PM
Pat80 Pat80 is offline
Default XT2 Push Button No Start
Thanks for the add. Im sure this is on here somewhere but I haven't founde a solution yet.
Have a 2 yr old XT2 with the ZKohler engine and push button start. However when I try to start the machine I get the lights and the hours but nothing else. All safety switches seem to be working since if I don't press the brake, sit in the seat, or have the PTO on i get the warnings from the computer as such.
Battery is new and charged with trickle charger. Have tried two different soloniods with no luck (bench tested both and they do work). Traced all wires as far as I can which all look fine. Also good fuse off the battery and clean ground.
I can jump the starter and machine runs as normal all day long and I can use the push button to stop the engine.
I'm at my wits end here, does anyone else have something I haven't thought of besides replacing the computer?
Old 05-15-2022, 08:15 PM
Is it still under warranty?
Up to 530 and counting...
Old 05-15-2022, 08:37 PM
Unfortunately no, missed that boat by like 2 months
Old 05-15-2022, 08:55 PM
Ozcub's Avatar
Ozcub Ozcub is offline
We have what is called a Statutory Warranty in Australia where equipment has a manufacturers warranty but something like that switch has an expected life and the expected life would be more and so it is covered by the manufacturer , this stops a lot of planned obsolesence
Oz
Old 05-15-2022, 09:46 PM
guyina4x4's Avatar
guyina4x4 guyina4x4 is offline
You say 2 years old?
Cub cadet warranty is 3 years.
JD x475
Old 05-16-2022, 07:54 PM
Thanks everyone. I will check on the warranty once I remember where i put the paperwork. I'd still like to know what my issue is since I have been working on this thing for weeks.
Old 05-16-2022, 08:17 PM
Inactive Member
Isn't that the job for the Warranty Service Depot ???
Old 05-16-2022, 10:00 PM
guyina4x4's Avatar
If you registered the warranty when you bought it, CC will have all the info they need.
JD x475
Old 08-07-2022, 04:22 PM
Andrew1045 Andrew1045 is offline
Same issues here Pat80 on my XT2..investigated same as well..Looks as if we landed in the warranty forum instead of the diag assistance, recommendation page. Feel free to reach out if you've made any progress. I would be interested to learn of your findings.
Old 08-07-2022, 04:42 PM
Inactive Member
Maybe if Cub Cadet would publish a Wiring Diagram and a Service Manual, for that model, we could offer assistance. Since that information is unavailable to us, and the tractor is under an OEM warranty, that recommendation is the only viable solution.
