Old 01-30-2022, 04:42 PM
bones7977 bones7977 is offline
Default '17 XT1-54 fab blowing fuse
I tried to start my cubby yesterday it started momentarily bogged down, stalled and I heard the 20 amp fuse pop. I have been tested wires all day and have not found a bare, broken or compromised wire. It has the 24hp Kohler. I live in Ohio and pull a salt spreader and plow snow with it. any advice would be GREAT!!!! Thanks all!!!
Old 01-30-2022, 10:01 PM
CubDieselFan's Avatar
Check your headlight wiring. Have you replaced it again? When does it blow after a replacement?
Old 01-31-2022, 07:51 AM
Inactive Member
Welcome to OCC.......
As a suggestion, unplug segments of your wiring harness, until problem goes away.
Old 02-02-2022, 10:05 PM
Farmall450's Avatar
As a suggestion, unplug segments of your wiring harness ,until problem goes away.
I'm guessing your salt spreader is electric powered? Shorted to motor case?
EDIT: Missed where you said pull. I would think it has to be a short or maybe bad PTO to pull 20amps on that.
