Old 05-07-2024, 05:28 PM
cnysabo cnysabo is offline
Default Remove rear axle carrier 1641?
Hello all-
I tried to search the forum before asking a redundant question... but is there a trick to removing the rear axle carrier on a 1641?
The top two bolts on each side snapped off (as I have seen is a common issue with these). So I have removed the remaining bolts that attach it to the differential. I also removed the c clip and slid the axle out. I just can't seem to free the axle carrier off the differential housing.
Is it the seal between the parts that has glued it shut? Or is it the "stud" of the broken bolts that is keeping the pieces together? I am trying not to break anything further then it is broken...
Thanks for any info!
Old 05-07-2024, 07:56 PM
What top two bolts? Do you mean the rear ale housing? You have to hit it a little harder as they are siliconed together.
Up to 530 and counting...
Old 05-07-2024, 11:31 PM
Thanks for the reply! There are 5 bolts around the housing. The top two on each side snapped (I believe due to the torque of the wheels). The bottom 3 were fine and backed out no problem. But the top two had the threaded part of the bolt still in the housing. I just wanted to see if it might be the threaded part of the bolt still runs through both pieces or if it was just adhesive holding it together. I will try a giving it a little more "english" and see if the seal releases.
Thanks again!
Old 05-08-2024, 09:14 AM
ironman's Avatar
ironman ironman is online now
Aren't there 6 bolts?
Old 05-08-2024, 10:09 AM
Yes, you're right. There are 6. I was going off memory...
Old 05-08-2024, 10:11 AM
Check your front tabs on the transmission also. It sounds like your rear was loose and caused the bolts to break. This is a common issue.
Here is where my 2072 was broken before I welded it back in place.
I suggest that you get a rear brace kit to keep this from happening again.
https://www.xtrememotorworks.com/Rea...d%20Parts.html
Old 05-12-2024, 06:50 AM
TheGrinch TheGrinch is offline
I have a center section if you need it. I already sold the axles and axle housings. I will GIVE it to you as I am getting ready to toss it, I am in VT.
2072 owner
Old 05-14-2024, 10:48 PM
Thank you so much for the kind offer! But I should be all set. I am just waiting for some new seals to arrive so I can put it all back together. Fortunately I didn't have anything on the transmission snap off such as Oak showed in his picture. I had a yellow bolt on bracket snap that supported between the transmission and the frame. I was able to find another to replace it.
Thanks again!
