Sleeve hitch
So in reading up on the 100's I've seen mentioned a sleeve hitch/adaptor. What is the purpose of it and does anyone have a pic of one installed on a 100? Thanks
The main purpose of the Sleeve Hitch, once installed on the tractor, is to pull, raise and lower rear mounted implements. See link: Sleeve Hitch
Go to the Cub Cadet Events section and watch some "plow day videos" to give you a prime example of a Sleeve Hitch function.
My 100 with a Sleeve hitch and adapter:
Project Uncle Dick Cub Cadet 70 http://www.onlycubcadets.net/forum/s...ght=Uncle+Dick |
100 with cultivator:
100 with moldboard plow:
Hitch
Hitch on a 72
Most folks use the phrase “sleeve hitch” and IH 3 point interchangeably. The IH style 3 point has the lift pin and associated parts as well as the bottom bracket. The sleeve hitch adapter package attaches to this. It’s the u shaped bracket on the bottom and the straps that go up to the pin.
This allows you to use Brinly style implements with the IH 3 point.
125, 127, 2x IH 682, 2x IH 782, 2084, 3225, 2x3240 |
Thanks for all the replies on the sleeve hitch question. Is the sleeve hitch model specific or will one fit all the narrow frame tractors? Thanks Dave
The reference to the Frame Width is based on the front of the tractors. See this link... Frames
Since the IH rear ends we pretty much all same up through the 82 series (S/N: 720,000> started the Aluminum rears), the Sleeve Hitch was the same.
Thank you for your reply. Dave
