Old 01-26-2019, 07:09 PM
gtpicker01's Avatar
gtpicker01 gtpicker01 is offline
Default 104 with hydraulic lift
FINALLY added this 104 to my collection today. I've been after the previous owner to sell it to me for about 4 years now, and after he replaced it with a john deere he was ready to part with it. Never had a cub with a hydraulic lift like this before and I'm really excited about it! It has a 48" deck and lights. Original engine took a crap in the 90's and it was replaced with a new k241 at that time. Had the lighter too, but it went missing at some point in time. I have a snow blade here that will fit it, but I'm not sure what I'll need to hook it up to the hydraulic lift.
Really happy to have this one!
Proud Owner of These Fine Cubs
1961 Cub Cadet Original - 1966 Cub Cadet 102 - 1967 Cub Cadet 104 w/ hydraulic lift
Old 01-26-2019, 07:25 PM
Inactive Member
Good for you.
Old 01-26-2019, 08:15 PM
Rmowl's Avatar
Rmowl Rmowl is offline
Good find, 48” deck is a bonus
-Rick
IH 782
IH 126
CCC 1863
Old 01-27-2019, 11:00 AM
Great things ARE worth waiting for! Glad you got your hydraulic lift. The 104 is a real fun tractor to operate. The blade for the front only requires you to obtain the blade (QA), a lift paddle (usually $10-$20), and a 1/2" lift rod. Then you are all set!! Have lots of fun on your 104!!
Old 01-27-2019, 12:04 PM
athomas's Avatar
athomas athomas is offline
Thumbs up
Welcome ! Nice Find !
Old 01-27-2019, 04:45 PM
This is what you need.
That and a lift rod, blade and a subframe for a narrow frame.
The part is a reworked version, per instructions in the hydraulic lift owners manual, of what would have been required if your Cub had a manual lift.
Post some closer pic's of your lift setup.
I have some of those parts made up, I have to bend the "U" yet on the bottom.
If you cannot find one drop me a PM.
Pic's are of my 126 restoration from a couple years ago
Good luck!
Old 01-27-2019, 08:56 PM
Nice 104, I have a 125 with one of those hydro lifts, any leaks?
Here are your choices for lift arm brackets, either one will work.
Up to 530 and counting...
Old 01-28-2019, 09:27 AM
gtpicker01's Avatar
Good luck!
Thanks for all the comments guys! I think I'm really going to like this tractor! I have the correct plow and found a lift linkage, but I'm going to start looking for that lift bracket for it. If I can't find one I'll let you know. Thanks!
Old 01-28-2019, 09:31 AM
gtpicker01's Avatar
Thanks for the pics! It doesn't leak, but the return spring is broken. I know where I can get a whole rebuild kit for it that comes with the spring and all the O rings and seals so that is what I'm going to put in it.
Forgot to add that this thing needs a little clutch work. Teaser spring is broken and I'm pretty sure it is because the drive shaft is so badly worn and it looks like the throw out bearing is junk too. I've seen some good youtube video's on how to take them apart so we will see how that goes.
Old 01-28-2019, 02:08 PM
Congrats on your 104!
