Back in action
Hello. Is been a while since I posted. I recently put a new battery in my cub and this is actually the first time I've really got to run it hard in over 2 years. After cleaning the gummed up carb, I used it to cut my field. As the sun was setting, I noticed that the muffler was literally glowing red.
Right before i noticed that it started running a little rough. I turned it off for a few minutes then started back cutting and the glowing came back. What could cause this?
Cub Cadet 149 Cub Cadet 126 Yanmar YM2500 |
Sounds like you may have carb problems. Glowing red exhaust usually points to a lean condition.
I see that new to you tractor. Come and get the box blade anytime. We just have to get a tree off of it.
Sticking exhaust valve will cause that issue too.
Queen Of The Quietlines! |
I found a great tutorial on how to tune these carbs. Between tuning carb, setting timing, and checking valves it should be running great afterwards. Adding that to the list to check. I've checked them before but its been a few years back.
