1200 running poorly
So adjusted carb a bit and seemed to be running fine for about 30 mins. then acted like it was running out of fuel , then a pretty loud back fire before stopping. Should not have run out of fuel, but could not get it restarted. Pulled plug and it was white in color and very hot. Tried starting today and back to square one with not starting. Changed plug, plug getting good spark . Anyone have any ideas?
Thanks, Joe Presently have : 100 1200 1250 |
Sounds like you have some sort of Fuel Delivery problem.
I second Roland's fuel problem comment. See if it will fire on a little brake cleaner. If it does then you know its fuel related
So this is the new carb you bought?
Yes it does have the new carb.
OK.. so you have a new carb. Did you clean the tank, lines, change filter/ sediment bowl, screen in tank?
White in color, lean condition.
Is this a Chinese clone carb? What was wrong with the old carb? |
Tried spraying some brake cleaner into carb while turning engine over, to no avail.
When I pull fuel line off from carb I have good gas flow.
Maybe it broke the connecting rod...does it have compression when you turn it over by hand?
