70 carb
Took the carb off the 70 today along with the fuel tank.
Can anyone school me on which carb this is? Evidently there are three different ones?? The numbers 4147808 ( could be 4147806- my eyes are getting bad) are in the side of the housing. The throttle shaft wobbles terrible.
http://www.onlycubcadets.net/forum/s...ad.php?t=42646 70, #1 cart. Brinly Cultivator. Some wheel weights. {125, 126, 2072-Sold~regrettably, 2284 60 inch Haban 325 deck., 451 snowblower, 2182-60 inch Haban 374 deck- "Money Pit", 401 Haban 54 inch dozer blade- rebuilt, 1440-down the road, Another 2182 for parts. Another 2284 for parts. 450 blower. 1812-sold, 2072 w/ Haban 374, and a 2182#3 w/ Haban 325}-------> All SOLD |
The fuel line had some very dry rubber gaskets which will need replacing.
Wire brush the top of the flange. The carb number should be there. Those rubber ferrules are about $4.00 a piece.
Doug Dad's 122 w/42" cast deck, spring assist, lights,weights, rear lift 1250 w/hydraulic lift, lights,weights, spring assist. 50C deck converted to an A with front wheels 44C deck converted to an A with front wheels. QA-36A 42" blade |
Tried searching the number you had, no luck. did come up with this though:
https://www.kohler-engine-parts.opee...nce_Manual.swf
Found this on top. 4105313
That is a Carter/ Kohler carb. Why does everyone get so worried about getting the numbers? You don't need them to order a kit. THEY ALL TAKE THE SAME KIT.
You can do a quick simple fix for that throttle shaft.... or at least usually you can: http://www.onlycubcadets.net/forum/s...ad.php?t=10329 You can get those rubber ferrules on ebay. 10 packs for less than $10. I don't recall what size they are. I'm not much for the old school steel line. I just switch it over to rubber. Easy peezy, and usually no leaks. No one cares if it has that "original" steel line, nor does it make it worth any more. |
Go to the link I sent earlier and go down to page 3, I think that may be your carb. Kohler inserts spaces between the numbers I guess.
Make the best of each day , Todd Original's Face Lift thread.http://www.onlycubcadets.net/forum/s...ad.php?t=34439 (O) Start to Finish video.https://www.youtube.com/watch?v=GAoUNNiLwKs Wheel Around videohttps://www.youtube.com/watch?v=XUL-m6Bramk They can't all be turn key! |
To me it's no different than replacing the battery with a "new" one, or replacing the old cloth wrapped wire with a new wiring harness. I prefer function over look on a fuel line. But, I digress. To each his own. |
