Old 08-12-2011, 09:09 PM
brentwd's Avatar
brentwd brentwd is offline
Default NF hydraulic cylinder leak
I have been chasing leaks on my 125. I had the unit rebuilt once and the company broke the gear that attaches to the main shaft. Got that fixed and it still leaked. The shop said the pump's relief valve was stuck shut. The owner of CC Specialties said there was not enough pressure for that to happen. So on to another shop and had to have the rod machined to replace the old one as the threaded end was almost broke and the shaft had some scarring. Got it back together and it still leaked, but this time it leaked between both the shaft and the outer tube and cylinder end. All the o-rings were replaced twice. Now the shop says the cylinder is junk and they can make a new outside tube, but I feel that should have been done in the first place.Am I wrong in thinking this way?
