D640 Valve Lash??
Is the valve lash on a Kubota D640 in a 1772 the same as the valve lash for a D600 in a 1572? I have the Service manual for the 1572/D600 but none for the D640.
1989 - Cub Cadet 1772 1987 - Cub Cadet 1572 w/Rear PTO & Cat. 0 38" Lawn Sweeper #196483 42" L42 (Bush Hog) Rotary Cutter # 190349 45" 2-Stage Snowblower # 196364 48" Haban Rotortiller Rear PTO Driven #190356 54" SnowBlade with hydraulic Angle #196376 60" Haban Mowing Deck #196374 |
They are basically the same engine, just one is sleeved and the other is not. I'd use the specs for the 600.
Thanks Jonathan! I ordered new a new valve cover gasket since the one on there was probably installed at the Kubota factory. No telling what shape it's in. I'll dig into that as soon as brown shows up at the door.
This is from a cub cadet manual for the 1782 with the D640B engine.
