Old 10-25-2014, 06:06 PM
Nightow1 Nightow1 is offline
Default Fuel sending unit?
Has anyone ever put a fuel sending unit in a 2182 tank, I know there's always a way, but was hoping that someone has done it to speed things along. I have a nice 1.5" fuel gauge and I'm planning to replace the dash with all gauges. I have found several adjustable units, but I just need some sort of starting point...
Old 10-25-2014, 06:15 PM
Just my 2 cents but the low fuel light is pretty simple and reliable. First pic shows how I did my 2182. Low fuel light is in the center. Second pic shows how I did my 1782. On the 1782 I retained the factory idiot lights that include the low fuel light.
Old 10-26-2014, 12:03 AM
I put one in my 1250 tank..its pretty easy, just have to bend the float so it reads correct...the sending unit i used was out of a boat....works pretty, i got some white faced gauges that light up, and they match the paint (by luck)... its nice though, i would think youll like it...
Old 10-28-2014, 09:22 PM
I meant works pretty good....
Old 10-28-2014, 10:11 PM
The only issue I see is, where to mount the sending unit. It is 1/2" tall above the tank. So i will have to do some thinkin!!!!
Old 10-28-2014, 11:41 PM
Cut a hole under the seat and mount it there. Can't see the hole that way....
Old 10-29-2014, 01:24 AM
That's kind of what I was thinking. Even with the seat moving back and forth I should have just enough room. I was going to cut the electrical connector down and solder the wire on direct since it is whats sticking up so high.
Old 10-29-2014, 10:04 PM
I have another one like that in the pic....only needs maybe .375" of clearance for wires and such....if youre interested??
Old 10-29-2014, 11:03 PM
I think I will be ok. I checked it out today when all my gauges came in, looks like it will just clear the underside of the seat pan.
