kt17 Cold Weather Starting Woes,...1711
hello folks, and happy new year! having trouble starting in the cold temperatures of 20* and lower. the tractor cranks over slow. just installed a new batteryand cables. nice clean plugs, gapped at .025, and clean points holding .019 thousandths gap. acceptiable spark varified on each cylinder. if i heat the shop up, warming the tractor after an hour, tractor starts, and of course the battery is being aided by battery charger too. once its running, preforms as should. seems like its always started up for duty, but i dont remember those winter temperatures of years past. ideas, experiences, and suggestions for this problem would be interesting to read about.
IH CUB CADET 1450, 72, 86, 1211, IH #2 CART, IH 56" SNOW BLADE, COLLECTING CUB CADET ENGINES |
If you are running SAE30, I would switch to a multi-vis oil (15w-40 is what I use year-round) to aid in starting/cranking. Factory calls for 10w-30 in colder temps.
It's also somewhat likely that your starter is getting weak and not able to use the battery voltage to produce the power it used to. As long as your connections are solid on the positive and ground side and you have no significant voltage drop across the solenoid, then the only issue left would really be the starter internals. Check voltage at the starter lug and confirm it is virtually the same as battery voltage when cranking.
http://www.solunagarage.com |
One thing that helped a hard starting 1210 that I used to own was running a ground wire from the battery to a starter mounting bolt. Cub has the battery ground bolted to the frame. I also up sized the cables and in the winter I put the battery from my race car in the tractor. Link to the battery.
https://www.summitracing.com/parts/d...RoCVScQAvD_BwE Expensive but it will spin the engine.
A shot of ether works well.
Why Farm Half When You Can Farmall? 1282 | 44C Deck, Chains, 42" Blade, Cast Weights, 020" Over K301 * 1711 | 50C Deck, #1 Rear Rototiller w/ Extensions, Sleeve Hitch, KT17S Series II 24302 --> CH18S * 1811 | 46 GT Deck, 42" Blade, Chains, M18 Magnum, Sleeve Hitch * 1782 | 60" #375 Deck, Kubota D640 Diesel * 1862 | #450 Snowblower, M18 Magnum * 782 | Y/W KT17 Series II, Sleeve Hitch * 984 | Y/W Onan/Linamar 20HP, Sims Cab, CAT 0 3 PT w/ Rear PTO, 60" #374 Deck |
Ok, check voltage at starter when cranking...funny that i forgot to mention that the starter does infact make a hi-pitch squeel often after engine pops off but when engine doesent stay running at first. now i'm suspect to it, thanks. i have anothe used starter on the shelf, but thats a bit of work on a used replacement part, lol!
sure does! when i do that, the engine stops cranking, as if too much compression. starter seeming even more suspect now,.. i'm glad i asked the questions! thanks everyone. i will report back.
A few thoughts on this subject:
The lawn and garden batteries as a whole suck in this weather, as most are low CCA. Try to get the highest CCA available. The starters on these engines are mediocre at best, as are the small gauge battery cables. The hydro oil is thick when cold, so cranking will be slower even with a decently thin engine oil I run 10w30 in my M18 powered plow tractor. I never have any starting issues.
582, 682, 782, 782D, 1282, 1050, 1210 x 2, 1711, and 1811 |
turns out to have been a bad starter. once i removed the engine, ( and i realized its much easier to reinstall the motor to the engine plate both outside of the tractor ) and then the starter, the starter bearings were severly worn/wrecked.
my spare starter proved to be functional so i installed it to the motor. put the tractor back together which was a a good sum of work and got out and pushed snow off the drive way! the high temperature today was around 25*. and was glad to see the engine spin over quickly again. i will be following through with a new starter, and the suggestions. thanks for all the help!
