Go Back   Only Cub Cadets > Off Topic > Gardens, Lawns and Landscapes
Old 09-17-2017, 06:35 AM
sluggomagoo's Avatar
sluggomagoo sluggomagoo is offline
Default Weird cut
I've been using an XTL1050 with a kohler engine for about 7 years now. I've never liked the way it mows. I sharpen my blades twice a mowing season, once int the late spring and once end of summer. I use two different sets of blade as I have some dedicated for the beggar that I only use in the early spring and fall.
Making a cut typically is only about 1/2 of the deck and the depth is about an inch to an inch and a half. The lever on the mower never is set to below the third stop from the top. I mow back and forth so the cut repeats in a different direction.
I get a seam of grass in the middle about two thirds higher then edge. I know the blades are installed correctly. The deck is attached correctly. Tire pressure is consistent on all 4 wheels.
What's Wrong?
Old 09-17-2017, 08:44 AM
john hall's Avatar
I would say aftermarket blades that are too short or your deck is bent causing one spindle to run out of "square" (not perpendicular to the ground). Did you buy this mower new? If so there is probably nothing you can do other than to make sure the spindle is running true.
Just re-read your post, you say the deck is attached correctly, but have you leveled it by the book? If not get on a good concrete surface and have at it. I level all mine to the blades using one of those plastic blade height measuring gizmos. I live surrounded by a bunch of HIGH DOLLAR Deeres, so I can't afford to have a ugly yard.
2072 w/60" Haban
982 with 3 pt and 60" Haban
1811 with ags and 50C
124 w/hydraulic lift
782 w/mounted sprayer
2284 w/54" mowing deck
Old 09-17-2017, 09:04 AM
Leadslingingdaddy's Avatar
Beggar? Thin Stamped steel deck. I'm more surprised it's lasted 7 years
Old 09-17-2017, 10:17 AM
Get one of these and as the others have said check the blades. I think those use the cheap decks that bend easy where the spindle mounts. I had one of those on a GT3100 and bent the deck trying to get a blade off.
Old 09-17-2017, 12:21 PM
Old 09-17-2017, 01:08 PM
That's an impressive thumbs up. Do you have one in Yellow and White?
Old 09-24-2017, 07:24 PM
Ozcub's Avatar
Ozcub Ozcub is offline
Also adjust tyre pressures to the book they should not be the same all round
Oz
Old 09-24-2017, 07:30 PM
I dropped the deck and cleaned it again. It was loaded up with mulch. I had to put on a different set of blade for the bagger for fall mowing. Next year I'm going to mow without the mulching plug because it seems to be a problem.
Old 09-25-2017, 09:28 AM
It was loaded up with mulch. Next year I'm going to mow without the mulching plug because it seems to be a problem.
Ya think???
Old 09-25-2017, 07:51 PM
Ya think???
