Front weight basket
A friend wanted something up front to counter the carryall I built for his 2082. So I put this together. We easy to make tilt so is now a dump. He will put proper pins in it, paint and make it pretty. I really like it and want to build another for myself.
I like it!
Better be careful not to run it into stuff
Terry O,100,72,102,123,104,124,105 125,129,149,1200,982 (2)2182s w/60in Habans 3225 |
Very nice! I like it too!!
Does it connect to the quick hitch or is it bolted on?
Jay 40 years of Using and playing with IH Cub Cadets! Proud owner of the following: Cub Farmall, Super A Farmall, Original, (2)70's, 72, 100, 102, 123, 105, 125, 127, 108, 128, 1450, (3)782's, Yellow 982, 1782, "Sam's" 2182, M Farmall and a #7 trailer |
Yup, nice job!
That looks handy for many things
Nice work. |
I went with bolt on only. Is easy to add a qa bar if he wants later. But the perches are annoying when it is off as they dig the floor and anything else you set it on. Thought about doing a car hood latch for a release. But he does not plan to work it as a dump. Am worried it will block the lights some, but we shall see.
Best part is material was free plus a couple angles I had. Even so that is a bit of welding. Added drain holes or it would be water tight. Added the rib around the top of the basket so it could be beat on. It is one tuff basket. And not very heavy. Thanks guys, I am pretty proud of it. |
Looks great. If lights are a concern pick up some cheap LED lights and mount on the sides. Just curious, how much counterweight is he going to put in there? Looks like it would also come in handy if you were hauling gardening supplies, fence repair supplies and towing a trailer or sprayer, somewhere to carry the chainsaw while towing a load of firewood/brush, etc. Lot of uses I see.
I like it.
Agreed, very handy! Nice job.
149, 2072, Original, 1772, 1782, #1 cart, Parker 48" sweeper, |
Looks great! May have to steal that idea for a rear weight basket!
Don 882D 50" Deck Mower 54" Snow Dozer Blade Agri-Fab Lawn Sweep |
