Old 01-04-2024, 09:45 AM
That_cub_dude1847 That_cub_dude1847 is offline
Default cub cadet original timed deck not working properly
Hi all,
I have a 62 original with the square 38" timed deck. I never really used it until recently. As far as I know its timed correctly as when i flip it upside down and spin the cogs, the blades don't hit. When its on the tractor, I can turn it on and they don't hit but when i drive over uncut grass, the blades it. What could this problem be?
Old 01-04-2024, 10:23 AM
sorner's Avatar
sorner sorner is offline
Are they close at all when turning them by hand? I have one that had the blade bolt come just enough loose that under load the blade would turn a bit and the blades would hit.
1912 with Kohler M18 engine repower, CI rear, 50C deck, 364 snow blower
IH Cub Original with deck
#2 cart
GREEN 314 with integral sleeve hitch, H2 and independent brake upgrade from a 317, and front hydraulic blade, 48" deck
Old 01-04-2024, 10:40 AM
Set the blades so that they are 90 degrees to each other. Page 6 on the owners manual.
https://www.onlycubcadets.net/forum/...ad.php?t=53161
Old 01-04-2024, 10:43 AM
sorner's Avatar
Yeah that's a good place to start for obvious reasons, but in my case the blade was turning on the shaft.
#2 cart
Old 01-04-2024, 12:17 PM
Yes, both aren't hitting each other and are set 90 degress opposite of each other
Old 01-04-2024, 12:59 PM
Worn belt, it may also not be the blades hitting each other, the may be hitting the deck. Are they the correct ones?
Up to 530 and counting...
Old 01-05-2024, 09:14 AM
jbrewer's Avatar
jbrewer jbrewer is offline
Worn belt seems likely. Also, where the blades are hitting should be pretty clear with a close look.
61 and 63 Originals
123 (2)
782D
106,
147, 122
102
parts
It's only original ONCE!
