Old 10-22-2018, 10:44 PM
Marinemp Marinemp is offline
Default 127 blew up...
Well my cub started shaking badly so I lowered my rpms and it sounded like a grenade went off and my hood blew up I knew instantly it was bad, anyways anyone know where I can kinda a replacement motor.
Old 10-22-2018, 10:54 PM
Wow!!!! Never seen one blow the whole jug off, that's crazy.
Where in Ohio are you located?
Pap's 100
Restored 108
1211 Dual Stick
1050
Old 10-22-2018, 10:57 PM
I'm in Geneva Ashtabula county, it was the strangest thing started shaking bad, I lowered the rpms. Right before I got it down to idle, it detonated.
Old 10-22-2018, 11:50 PM
Farmall450's Avatar
How low on oil was it?
Old 10-23-2018, 12:31 AM
The sad part is I just did a oil change on it the weekend before it was filled up perfectly
Old 10-23-2018, 12:38 AM
Gompers Gompers is offline
Oh man sorry it blew up, but at least it was a spectacular failure.
Good luck finding a new engine!
125, 127, 2x IH 682, 2x IH 782, 2084, 3225, 2x3240
Old 10-23-2018, 12:40 AM
Billy-O's Avatar
Billy-O Billy-O is offline
Nasty! If it ain't low oil then next thing comes to my mind is how thin is the cylinder wall.... as if it could have be bored over during a rebuild? Or was it some other problem?
Plow blade
#2 Cart
QA36 snowthower
Old 10-23-2018, 12:48 AM
Farmall450's Avatar
Well that sure doesn't make any sense. It's not a KT17 series I
Old 10-23-2018, 09:12 AM
Nos & turbo @ #20 boost will do that
Now that is what they mean when they say "it done blowed up"
Old 10-23-2018, 09:17 AM
cooperino's Avatar
I believe you when you said you had oil in it.. Just surprising there is not oil all over the place. Looks dry
