Old 06-17-2011, 04:27 PM
MOturkE's Avatar
MOturkE MOturkE is offline
Default IH CC 122 Serial number... ?
So, I've looked in the two places on my 122 where the serial number tag is supposed to be and it's not there. In the manual it shows a flat spot molded into the right side of the rear of the tranny as one of them, there's no flat spot there. Also, they show there should be a tag riveted to the flat spot at the top of the rear of the tranny, there's no tag and no rivet holes, either. Now I'm stumped. I read somewhere that the number is usually stamped into the reduction housing... Does anyone know if that's the right or left side, and would I need to remove the fenders and seat assembly to read it? I really want to find out when it was built, also to keep the number in our records.
Proud to own a 1965 Cub Cadet 122.
Old 06-17-2011, 06:25 PM
There are three locations it could be in.. See pictures below:
Old 06-17-2011, 07:40 PM
MOturkE's Avatar
Default Eureka!!!
YESSssss! I think,... I found the spot just forward of the right rear axleshaft as shown in your second photo. THANK YOU! For the help! However, there are two numbers there; one on the lower half reads 133001, the one on the upper half reads 133621. The lower one is die stamped deep and the upper one is very shallow and a bit faint. But, I now have numbers! Thanks again!
Old 06-17-2011, 07:46 PM
Try to get us a good clear picture if you can.
Old 06-17-2011, 07:50 PM
Looks like with either number it was born in Nov. of 1965.
Old 06-18-2011, 10:16 AM
MOturkE's Avatar
Default Photo
Here's a photo of the serial #'s on the tranny...
