2084 engine
Did the 2084 come with both the Magnum and later the Command engine?
Should have only had the Command. The 2084 I just sold was one of the first 100 off the line and it had a command. I believe the 2082 would have had a Magnum.
AJ
1980 [COLOR="Red"][/COLOR]482- Stock 1981 [COLOR="Red"][/COLOR]582- Mag18, Sleeve Hitch, Spring assist 1979 [COLOR="Red"][/COLOR]682- Mag18, Sleeve Hitch, Spring Assist, #1 Tiller 1980 [COLOR="Red"][/COLOR]782- Mag18, Sleeve Hitch 1983 [COLOR="Red"][/COLOR]982- Stock, Fully Optioned |
It also showed a PTO belt 6" longer, a different PTO clutch, and some other parts I can't remember with different part numbers after a serial number break around 850,000. I think it even showed the gas cap as the small one, not the later, bigger one. Mine has a Command engine in it. |
