Drive train issues AGS Cub
I purchased a Cub of a coworker for $50.oo, it's a 2160. The drive-train is slipping somewhere. I took the drive-shaft out and there is these blue cylinders in what's called the drive-shaft barrel at both the engine side and the rear end side of the drive shaft. They were dust, so I got the blue cylinders and replaced them. The tractor rode good for a short period, and stripped out again. I also think the clutch needs to be adjusted or shimmed. I've seen some things about that problem online. Do I part this thing out or fix it? Everything else is in good shape motor runs strong not sure I like the AGS system.
I know absolutely nothing about that particular drive system. But, pounded the drive barrels out I'd say either you have an alignment issue with the shaft, or the inside of the trans is junk and it's putting too much stress on the driveline. I've heard that those trannys are junk. Sorry I can't be more help.
Thanks for the thoughts the system looks kinda weak to begin with as soon as a day frees up I'm going to start pulling the rear end apart to see what's happening ill keep updated
Some thing is very wrong if it is eating the barrels. I have never seen them go bad. The AGS is not worth you spending any serious $$$ on but if you decide to get into it here is a link on the fix
http://www.mytractorforum.com/showthread.php?t=143213 If you want a free rear for one I have one out of a 2160. It works but the clutches are extremely grabby. No slip at all.
You have one your willing to give me really? how do I figure out what it will cost to have it shipped?
I'll see if I have a box that it will fit in and see what UPS wants to haul it to you. PM me with your shipping info.
Thanks for all the help guys I just had to srart taking stuff apart the guy that had it befor me had three mounting bolts missing on the the rear end / tranny so it was moving like crazy everything is sucure and nothing is stripping now
