the mystery of the 1415 hot ammeter wires has been solved!
took the flywheel off and the stator had a worn/bare wire grounding out on the engine block.....now if i can just figure out why the pto is stuck on
Good to see the problem is discovered. Clean up the problem and try to remedy the possible cause.
dieblossom - note of caution - when engine is running/working hard, gets right hot where that wire sits. If you've used tape to re-insulate the bare spot, make sure it's the high temp type - regular plastic black tape won't stand up, IMHO.
thanks rcbee! i took the old white wires off and replaced them with new same gage wire and put new heat shield sleves on each wire. it looked like the person before me had the stator apart and wasnt paying attention when he/she bolted back on and crimped a wire. so far so good all systems are a go
Cool ! Looks like yer way ahead on this one. Hope it all holds up
well !! |
