Old 11-03-2010, 06:47 AM
cbrown cbrown is offline
Default Cub cadet 106
Hello everyone, I am looking into purchasing a cub cadet 106. It's in need of restore but seems to be complete. Anyway, I am wanting to know on this 106 is there certain things I should check before buying? It runs and does not smoke. Just wondering if there are flaws with this model of certain things I should look over? I have a 102 with internal brakes and I believe the 106 has external brakes. Is there anything I should be aware of as to the brakes? Any help would be greatly appreciated. Thanks!
Old 11-03-2010, 08:27 AM
T-Mo's Avatar
T-Mo T-Mo is offline
Chad,
Nice find on the 106. It will pretty much be equivalent to your 102. It's a couple of series newer than your 102, but is still a narrow frame. The main difference is the grille, dash and fenders (the 106 has a one piece fender deck while your 102 has separate fenders and foot rests). Most of the changes between the two models is cosmetic.
BTW, my friend Buzz was telling me about a 104 in Desoto - he might go look at it - if he doesn't want it I'll let you know. I have three 104s already.
Old 11-03-2010, 06:02 PM
ihnick's Avatar
ihnick ihnick is offline
i'd say look for "goodies" on it
Nick.
Old 11-03-2010, 07:14 PM
jarkin's Avatar
jarkin jarkin is offline
i second that.. stuff like wheel weights are pretty pricey
Old 11-04-2010, 10:14 AM
Default cub cadet 106
Here is a pic of the 106 i'm looking to buy. The guy says that it was last ran a year ago. I would think fresh gas, a carb clean and a hot battery and it should run. I got him talked down to $125. Should be worth that? cub cadet 106.jpg
Old 11-04-2010, 01:20 PM
T-Mo's Avatar
Chad,
I remember seeing that on CL. Since it wasn't a wide frame, I didn't check into it. I think he was wanting $200 for it if I remember correctly. I believe the deck was shot? Good luck.
Old 11-04-2010, 02:30 PM
CCdude's Avatar
CCdude CCdude is offline
I would be inclined to pass on that unless you can see the engine run. I bought a 106 like that. The guy said the engine ran, it just needed the carb rebuilt, well that turned out to be a bunch of . The rod was shot and the oil had turned into black sludge in the oil pan. I ended up rebuilding a 12 hp for it. You can also figure the rest of it needs rebuilt as well. Steering, clutch, pto, brakes, etc. If it had goodies then it would be another story, but from the picture it looks like a weathered, plain jane 106 with no attachments. I guess what I'm trying to say is don't expect it to be a $125 tractor, expect it to be closer to $1000 when it's all said and done with. If you feel it's worth it then go for it, i'm just giving you the opinion of a college student with no money, who has btdt.
Old 11-04-2010, 06:53 PM
Terry,
Yes, this is the cub on CL and i was mainly looking into it for a good workhorse around my property. I am going to look at it tomorrow and was just wanting some insight as to things i should look out for. I think this model has external disk brakes and are they prone to have issues? Don't have to be pretty just tough and able to take a beating hauling wood from the back of my property.
Old 11-04-2010, 11:23 PM
The 106 will have no problems, hauling wood around your property.
Old 11-05-2010, 03:52 PM
T-Mo's Avatar
Chad,
So did you get it?
