Old 05-29-2018, 07:16 PM
dagenham dagenham is offline
Default Graphite button on pto clutch
What tricks and tips do any of you have for installing the little graphite button on the pto on a 127? I bought it but not sure about putting it on without breaking it.
Old 05-29-2018, 08:39 PM
Don't use it. Get a brass one from JeffinPA on this site. The OEM graphite doesn't last long.
If you want to use it..... install carefully.
Old 05-29-2018, 08:41 PM
Install it with a small C clamp, it has to be pushed in straight to avoid breaking it. It's possible to put it in with pliers or channel locks but they break about 50% of the time.
Pap's 100
Restored 108
1211 Dual Stick
1050
Old 05-29-2018, 08:54 PM
Take a piece of sand paper and make a mini dur dur with it. After you remove the old one clean the hole with it.
Then unroll said dur dur and sand the first 1/8" of the button on a taper. Stick button in the hole.
Then use the PTO arm adjusting turnbuckle to set the fiber button in the hole.
After it don't go in no more, slightly tap the PTO arm with a with a hamma.
That is how we do it here.
Up to 530 and counting...
Old 05-29-2018, 10:22 PM
sawdustdad's Avatar
dur dur?? Had to look that up in the urban dictionary. Cardboard tube in the middle of a roll of toilet paper.
Who knew? Is this an amazing site or what?
Concur on the method above, that's how I do it. But I am experimenting with bronze buttons, too.
I've found that if the PTO clutch center button is not smooth, then it will eat the new fiber button. If it is smooth, the button will last at least a couple years.
