Go Back   Only Cub Cadets > Cub Cadets > Cub Cadet Engines > Onan Engines
Old 08-18-2013, 12:03 AM
jcrews's Avatar
jcrews jcrews is offline
Default Found an Onan for my 982
Hello
Well after nearly 5 years I finally found a replacement Onan for my 982. The po said that the engine runs fine but it smokes and has had sitting in storage for a few years he said it was cheaper for the linamar block than to rebuild. I know the rings need replacing but should I replace the piston and connecting rod ?
What else should I need to replace?
Thanks for any help
I H Pushmower,100,104,124,1450,1650,782,982,154 LoBoy,185 LoBoy,2 Farmall A's , Farmall H, and 8 IH trucks
Old 08-18-2013, 09:54 AM
Leadslingingdaddy's Avatar
Look for a 2000 series Cub with a Command engine in it and replace that Onan...All the JD guys are doing that since they are obsolete now....I did it to 3 of them...
You are looking at approx. 1100 to 1500 for a total rebuild..
Old 08-18-2013, 11:26 AM
J, if you get the Onan I would change the rods and pistons but as Randy said it may be cheaper to do the Kohler swap.
I have not purchased anything from these guys but they seem to have a good selection of parts.
http://onanparts.com/
Here is a good link on a rebuild.
http://www.mytractorforum.com/showthread.php?t=91204
Good luck and take lots of pictures for us.
