Old 01-20-2017, 05:14 PM
hogfly hogfly is offline
Default Sims cab
hello all i have a ? will the sims cab of a 1811 fit a 1863 and can you still get side doors wiper motors etc never had to deal with a cab would not know where to look thanks kenny
Old 01-20-2017, 05:23 PM
CubyFan CubyFan is offline
You will have a few problems the fender mount made for the 1811 are flat angled and will not fit the rounded fenders of the 1862 (cyclops) series. The cabs are much more rare than the tractors, it is much better to get t tractor to fit the cab. I have a couple of cabs and have have found aftermarket parts but SIMS no longer supports those older cabs for parts. If you post some pictures and name the parts you need I'm sure we can give you more specific suggestions. I am just about finished restoring a SIMS cab for a 1872. I will post a thread soon.
Cheers, Rick
Old 01-20-2017, 05:30 PM
Default sims cab
sorry for the typo the cab is off a 1711 and i want to put it on a 1863 thanks guys
Old 01-20-2017, 05:59 PM
Same problems - same body style.
Cheers, Rick
Old 01-21-2017, 07:49 AM
You can probably make it fit. Probably better to find the proper cab. If you do put it on the Cyclops be careful drilling the fenders, the gas tank sits up tight under them. I bought a Cyclops that the PO installed a cup holder on the fender, yep drilled and screwed it into the gas tank.
