Old 07-30-2012, 08:59 PM
theunit's Avatar
theunit theunit is offline
Default 2182 axle tube gasket replacement
got some leaky axle tube gaskets on the ol 2182 and wanted to ask about how to remove the tubes. does the axle just pop out and then in? thanks for any input, as this is my first time
Old 07-30-2012, 09:32 PM
Remove the rear wheels, brake calipers, pull the rear cover, remove the c clips on the axles and pull the axles. Remove the seals and replace then replace the parts in the reverse order. Put a new gasket on the cover and reinstall. Refill the trans with Hy-Tran. Let the good times roll.
Old 07-30-2012, 10:35 PM
SumBum's Avatar
SumBum SumBum is offline
Do what Sam said except take some pictures between each step.
Old 07-31-2012, 12:05 AM
I would also replace the axle seals also.
Old 07-31-2012, 08:32 AM
Opp's I thought he was talking about just the seals at the end of the tubes. If you need to replace the gaskets between the tubes and the trans then you will have to remove the whole rear end. Unhook the drive shaft, the shift linkage, unbolt the trans from the frame and roll it out from under the tractor. I'd pull the seat pan and fuel tank. Pretty much take the complete rear of the tractor apart. Fun job. NOT. If your in that far I'd also change the gasket between the pump and the rear. Not a question of if it leak but when will it leak. If you don't it will probably leak soon after you put it all back together.
Old 07-31-2012, 11:07 AM
Gaden's Avatar
Gaden Gaden is offline
...If you don't it will probably leak soon after you put it all back together.
That's the way things work for me.
Old 07-31-2012, 11:24 AM
Same here, my 2182 has dribbles between the pump and the trans. Gotta pull it and fix it one of these days.
