How loud are Command engines?
Those of you that have been around the Command engines in the Cyclops machines, just how loud is the exhaust supposed to be? I swear mine is the loudest thing on the farm. Initial inspection of the muffler shows no holes. I'm wondering if it is burnt out internally or if someone has tried knocking the baffle out of it. I wear ear plugs when mowing, but this thing is still obnoxiously loud. Even at a fast idle this thing is loud. Looking for a little feedback before I order a new muffler (you know that ain't going to be cheap). For the record, my Magnums, KT or the Onan even come close to this for volume.
When I did the command swap on my 782 I can say the ch18 was considerably quieter than the kt17.
1872 - 60"haban 54" power angle haban blade '63 Original - restoration project 582 -tiller 147 - leaf duty with bagger. 1811 - Ditch mower 800 - have it just cuz its a 800 |
Replace the muffler John. It isn't supposed to be that loud.
Thanks guys. For whatever reason, we rarely have to replace mufflers on anything, not just lawn mowers, and then they are rotted through to the outside. I'll start pricing them. I'll price Kohler and Cadet--suppose I better make sure this is not unique to a Cadet application.
Well Cadet is sure proud of it. I only paid a little more for the entire lawnmower! I'll search around some more. Who knows, maybe a custom muffler is in its future--thank goodness I know guys that can weld!
751-3110 MUFFLER KOHLER V Price $275.57
Maybe someone has a good used one....
IHCCW has them used. Hey its end of season so a used one will show up somewhere/sometime in the next 6 months.
I actually thought i had one..... ill have to look. Don't let me forget.
FWIW. I have an assortment of Magnum, Command and Vanguard twins.
The Magnums seem the quietest followed closely by the Vanguard. The Command is louder. Then there is another Command that is much louder than the other Commands I own. It is on a tractor I bought that had accompanying paper work from a dealer that stated the muffler needed replacing because of a blown out internal baffle. No visible external holes. As noted above, due to the pride CC takes in it's product pricing, I will continue to drive on like it is. |
I love the sound of my good Command CH18. I can hardly hear it over the grass crying. If it's loud, the muffler has an issue. I wouldn't run it too long if it's leaking, I have some experience on this subject ... I had melted plastic on the air cleaner cover and valve cover from a leaky loud muffler blowing exhaust heat directly up from behind the heat shield... and probably other ventilation issues exacerbated the issue... but I think mostly it was the leaking muffler.
1912 with Kohler M18 engine repower, CI rear, 50C deck, 364 snow blower IH Cub Original with deck #2 cart GREEN 314 with integral sleeve hitch, H2 and independent brake upgrade from a 317, and front hydraulic blade, 48" deck |
