LTX1045 blades cut out
Recently the belt got fried on this '09 cub cadet LTX1045, with a 46 in deck. Replace the belt with a 101 3/4 because what it called for a 108" belt which was so big it wouldn’t even stay on. Any how, replaced the belt. I go to cut, drop the deck down to a 4, and the blades just turn off like you pulled the PTO lever up. I lift the deck back up and they turn back on. Any thoughts? Been battling this and no one has ever had this happen I guess.
First, welcome to OCC.........
A 2009 LTX1045 w/46" mower deck, uses belt: 954-04219 which is 1/2" x 103.25". Using the correct belt and proper routing will put your machine back in duty.
See and that one felt overly loose. Is there an acceptable amount of play within that belt?
Use the OEM belt or the right size.
I put the oem belt on the 103. It’s “overly loose” meaning I can pull the belt off by hand with the pto engaged. The blades still stop spinning once I reach the deck height mark #4. I still can run the 101 and have it be a “perfect fit” but the blades still cut out.
Sounds like the belt is NOT properly installed (or routed).
It is manually engaged by a PTO lever that tightens the deck belt. I think he is asking how much "slop" should there be when the lever is dis-engaged. My guess is (assuming he has the correct belt) he has it routed wrong. |
I wish that was the case. But according to the diagram provided on the deck all is correct. I honestly don’t understand this dang mower.
Everything is routed correctly.
Obviously, something is wrong and not OEM.
