Wide frame engine removal/install
I have removed and replaced engines in wide frames before. I have always removed the engine and cradle together, unlike the manual, which shows removing the engine and leaving the cradle/iso mounts bolted to the frame.
My question is, if I lift the front of the tractor off the ground, does the front axle have enough swing to access the engine mounting bolts, or should I stick with wrestling the engine/cradle back into the frame as a unit? Doing it this way is a PITA to get the rear iso mounts installed... |
Yes, that works. I just pulled the engine out of my 1450 that way a couple weeks ago. The worst part is trying to get the bolts started straight going back in.
125, 126, 147, 129, 149 x 2, 1450, 882, 1810, 1320, 1440, 2135, 2 129’s for parts/project, 1950 Farmall Cub 38" LT mower deck, 4 42" triangle mower decks, 2 44A mower decks, 2 50C mower decks, 42” GT deck, 3 42" snow/dirt blades, 42" landscape rake, #4 cart |
Tried it this evening. It was wayyyy easier to bolt in the cradle first, then set the engine and bolt it in. Thanks for confirmation!
