Old 08-28-2015, 10:44 AM
pullin pullin is offline
Default Break Away Kill Switch.
I'm looking for the proper way to wire a break away switch on a model 126 for pulling.
Old 08-28-2015, 10:49 AM
I would think wiring it into the positive wire running to the coil would be the most direct way.
Pap's 100
Restored 108
1211 Dual Stick
1050
Old 08-28-2015, 11:16 AM
There are 2 wires coming out of the break away switch. So your saying run 1 to the + side of coil. then would I ground the other wire?
Old 08-28-2015, 11:31 AM
Berwil's Avatar
Berwil Berwil is offline
No, take the wire off the plus side of the coil, connect that wire to one of the kill switch wires, connect the other kill sw wire to the pos side of coil. Your just passing current through the switch, if you fall off, the switch breaks current which stops the engine. You can do this at any convienent point along that wire, where coil positive leaves the ignition switch for example is probably closer to where your mounting the kill sw. My only question is what is the amperage rating if the kill switch? If the coil draws more current than the kill switch can handle, the sw could fail at an inopportune moment (mid pull), a relay may need to be added to prevent that.
Bill
Old 08-28-2015, 12:20 PM
Ok, I will have to look into that. It is just a break away used on a trailer.
Old 08-28-2015, 01:28 PM
I don't believe that will work then, the break away on a trailer doesn't supply power until you pull the pin.
Pap's 100
Restored 108
1211 Dual Stick
1050
Old 08-28-2015, 02:06 PM
CumminSHO's Avatar
CumminSHO CumminSHO is offline
[QUOTE=Berwil;343413]No, take the wire off the plus side of the coil, connect that wire to one of the kill switch wires, connect the other kill sw wire to the pos side of coil.
Berwil can you please translate your abbreviation. Sorry sometimes it's hard to follow what someone is trying to say when you don't know what they meant by their abbreviations. Thank you
1965 IH Cub cadet 102
Brinly 10" plow
42" deck
Front mount snow blower
Front Mount Push Blade
Red Spring Aluminium clutch
Old 08-28-2015, 03:16 PM
Berwil's Avatar
No, take the wire off the positive side of the coil, connect that wire to one of the kill switch wires, connect the other kill switch wire to the positive side of the coil. Your just passing current through the switch, if you fall off, the switch breaks current which stops the engine. You can do this at any convienent point along that wire, where coil positive leaves the ignition switch for example is probably closer to where your mounting the kill switch. My only question is what is the amperage rating if the kill switch? If the coil draws more current than the kill switch can handle, the switch could fail at an inopportune moment (mid pull), a relay may need to be added to prevent that.
I think I fixed them all.
I agree with Tim about the trailer breakaway switch, I beleive those switches are normally open. I (we) thought you talking about something more like this.
tether switch
Bill
Old 08-28-2015, 06:08 PM
dvogtvpe's Avatar
dvogtvpe dvogtvpe is offline
do you need to turn off a fuel pump? if not hook one wire to ground and the other to the negative side of the coil. that will ground the points to turn it off. if you have a fuel pump then you need a normally closed relay and a ground supplied when the switch is pulled that opens the relay. the 5 terminal Bosch relays work good for that.
Old 08-28-2015, 09:34 PM
You are correct but you will also cause the coil to heat up and prolly burn up if
forgotten and not disconnected with ign switch,and or the battery go dead.
Don't like that method, but it will work.
