Old 08-18-2019, 12:01 PM
Wildwil532 Wildwil532 is offline
Default 149 PTO confusion
I just got a 149 yesterday. The PTO isn't set right or the turnbuckle it whines/grinds. The PTO has the brake that's attached to the PTO rod. But when I look at diagrams of the difference of the ptos available to the 149 mine has the 3 prong pressure spring but has the brake as well. The diagram shows that isn't supposed to be that way. Is what I have just cobbled together then?
https://www.onlycubcadets.net/forum/showthread.php?t=9
Old 08-18-2019, 12:35 PM
Inactive Member
First, Welcome to OCC....
Yup, sounds like it.
Old 08-18-2019, 01:26 PM
Thanks I've lurked around for a while just reading and trying to learn things before I got something.
Old 08-18-2019, 02:01 PM
You might post some pictures, and someone might be of help.
Old 08-18-2019, 02:24 PM
I will when I get home. How would I know if this PTO wasnt initially a non brake PTO? What's the point in the brake? Can I use a non brake PTO if this is really one with a brake.
Old 08-18-2019, 02:45 PM
Inactive Member
IF you go back to that PTO Parts Guide, it says Tractors with Serial Number with 482000 and greater. It was in Aug '73 in Mid-Production of the 1x8/9 Series.
Old 08-18-2019, 03:29 PM
There's the tag I'm still at work but I'll get picks up of the engine setup tonight.
Old 08-18-2019, 03:30 PM
2050047u5247705
Old 08-18-2019, 03:49 PM
Inactive Member
YOUR tractor ( since it is above 482,000 ) had the PTO w/Brake.
Old 08-18-2019, 05:12 PM
