Old 09-03-2019, 09:08 AM
Cub123Guy Cub123Guy is offline
Default Cub Cadet 123 Lug Bolts
I have finally gotten my 123 in good enough (so I thought) shape to mow. Yesterday I went around a turn and all of a sudden fell over like I was in a hole. Well the left rear wheel had fallen off with only one half back out bolt holding it. I walked around till I found another to put on so I could get it back up to the garage. I can’t find the other 3 and these 2 are ruined. I was hoping I could find a source either local or on amazon for the rear wheel lug bolts? I would try to look locally but I don’t know what size or anything that I’m looking for... any help is appreciated
Old 09-03-2019, 09:45 AM
MBY852's Avatar
MBY852 MBY852 is offline
You can find them from the sponsors at the top of the page. Cub Cadet Specialties has them. Click on wheels and scroll down a bit and you'll see the lug bolts. They can get a bit pricey with the shipping. Also put an ad under wanted items on here. I'm sure someone could help you out there. I don't think you'll find them at your local hardware/automotive store.
CC Model: 127 w/42" deck
CC/MTD Model: 2155 w/42" deck
.....DAD bought em new.....
Old 09-03-2019, 09:51 AM
Billy-O's Avatar
Billy-O Billy-O is offline
I believe you are looking for 7/16-20 wheel bolts.... I'm not positive of the thread size! There are nuts, studs and bolts. Use "wheel bolts" in your search. Plenty around.
Plow blade
#2 Cart
QA36 snowthower
Old 09-03-2019, 09:55 AM
You can buy 7/16-20 bolts and put them in the axle from the backside and then use regular lug nuts. Lots of guys do this to make it easier to mount the wheels.
Randy
2 original cub cadets
1 100's
2 149's
1 73
1 2182
Old 09-03-2019, 10:09 AM
cooperino's Avatar
If you have a fastenal or a decent hardware store near by, they should have the nuts, studs, bolts, etc to do it the way you want.
Old 09-03-2019, 10:25 AM
I replaced the bolts with studs on the 149 I used to own. McMaster had everything.
94846A520 jam nuts https://www.mcmaster.com/94846A520
98750A474 Studs https://www.mcmaster.com/catalog/125/3268
4991T964 lug nuts https://www.mcmaster.com/catalog/125/1466
Old 09-03-2019, 10:59 AM
ironman's Avatar
ironman ironman is offline
Randy
Ditto to this, but otherwise there are tons of them listed on eBay. Just search "cub cadet lug bolts".
https://www.ebay.com/sch/i.html?_fro...bolts&_sacat=0
Old 09-03-2019, 09:31 PM
As a machinist, I will confirm the 7/16-20 NF thread size.
Jeff
Old 09-05-2019, 12:46 AM
I think you will find it easier to operate if you have 4 wheels on your cub. I don't dig the "low rider" profile you are trying to fashion. Just not for sure why you want a "crazy wheel" on your cub cadet. Not good on any cub cadet, least of all on a 123!!!
Beyond just replacing the lugs on your wheel, the bigger question is, "What made them fall out in the first place?" Before using it again, I would spend some time looking into this before the result is worse than what it turned out to be for you. You could be seriously hurt or you could hurt someone else. This is not a normal wear and tear on a cub cadet, so a little investigation can be worth a lot of regret. Also, inspect your hydro tubes underneath your cub for damage. There is a minor protective cage around them, but if you went down at an angle, then your cub may have sustained some damage. Hope all is well with your cub and that you are back in action soon! The 123 is a terrific tractor.
