982 Front Wheel Bearing Spacers
Has anyone seen these, or have a P/N?
I thought both of my fronts did, but either one rolled away in the shop, or didn't have one originally when I popped the bearings out. I don't really want to put it back together w/ new bearings and no spacers, but I don't see any sign of them on the CC parts site. Current situation: I have 4 new bearings, 1 spacer, and 2 rims with new tires
Why Farm Half When You Can Farmall? 1282 | 44C Deck, Chains, 42" Blade, Cast Weights, 020" Over K301 * 1711 | 50C Deck, #1 Rear Rototiller w/ Extensions, Sleeve Hitch, KT17S Series II 24302 --> CH18S * 1811 | 46 GT Deck, 42" Blade, Chains, M18 Magnum, Sleeve Hitch * 1782 | 60" #375 Deck, Kubota D640 Diesel * 1862 | #450 Snowblower, M18 Magnum * 782 | Y/W KT17 Series II, Sleeve Hitch * 984 | Y/W Onan/Linamar 20HP, Sims Cab, CAT 0 3 PT w/ Rear PTO, 60" #374 Deck |
The large washer that sandwiches between the 3/8"-16 wheel retaining bolt and the outer wheel bearing?
582, 682, 782, 782D, 1282, 1050, 1210 x 2, 1711, and 1811 |
Either only one had it, or both did and the other one rolled away when I knocked out the bottom bearing (I had the wheel in the tire machine at the time).
In my IH Cub Cadet TC-193 Parts Manual, there lists NO spacers in Section H, page 60.
The little ones don't have any, but I understand why you'd add one.
Good news. Cleaned up the one I had and it's clearly homemade. Someone cut galvanized pipe with a sawzall (not very square either). Moved on without them.
