Old 05-08-2024, 02:49 PM
Fuzzcheek1 Fuzzcheek1 is offline
Default 3206 Axle Seals
Hey everyone. I've got an early version 3206 (1J310G & Before) that's leaking fluid past the axle seals pretty badly. I've looked just about everywhere online and these bearing blocks seem to be NLA. Is anyone aware of a seal replacement I could put into my existing blocks? Thank you in advance!
Edit: I'm also trying to find the best way to remove the axle from the housing. It looks like it should come straight out the back with the covers removed, but the diff lock seems to be holding it in place. Is there an easy way to remove the diff lock? Or is there something else I should be doing to remove this and replace the seals. Again thanks!
Old 05-09-2024, 08:31 AM
Here's my 3165 repair. It does not have the diff lock but everything else is the same. A few years ago my 3205 started leaking and I resealed it. I don't remember any issues with the diff lock on it.
https://www.onlycubcadets.net/forum/...ad.php?t=33446
This is a 10 year old thread. The seals are 30x40x4 and can now be found pretty cheap.
https://www.motion.com/products/sku/02336089
Old 05-09-2024, 06:44 PM
Thank you so much!
