Courage V twin
I have a 25 HP Kohler courage V twin vertical shaft engine in a Cub Cadet.
Model # SV730-0011 Ser # 3608135143 The problem is the starter wont turn it past the compression stroke. I have adjusted the valves to specs,installed a bigger CCA battery.The engine has about 700 hrs on it and runs great but I have to use a jump starter to crank it over, It has been this way since the first 100 hrs. I have been told it may be the compression release on the camshaft.Does anyone have any input on this problem, or know of any Kohler updates pertaining to this. Any help greatly appreciated. Thank to all, Jim |
Here are a couple threads you may want to check out.
http://www.onlycubcadets.net/forum/s...ad.php?t=42634 http://www.onlycubcadets.net/forum/s...ad.php?t=39441 http://www.onlycubcadets.net/forum/s...ad.php?t=43225
Courage V twin
I just looked at these posts and the only one I haven't done is pull and disassemble the starter. All grounds and cables connections are good. I did have a loose cable on the solenoid and it had gotten pretty warm at some point last year. The solenoid has been replaced and still the same problem. Parts Tree shows no compression release and even the camshaft is not available anymore.
Some of the pulling Cubs use an automotive starter conversion on their high compression engines. They use a Toyota Camry starter but it may not work on my engine. Thank you for the help. |
Jim, sell that thing at the Roger's machinery sale!
Queen Of The Quietlines! |
I cant imagine that engine has that much compression..?
X2! There is some other problem here.
Terry O,100,72,102,123,104,124,105 125,129,149,1200,982 (2)2182s w/60in Habans 3225 |
I have jumped it directly to the starter and engine block, and on the battery also. Doesn't seem to make any difference.
If you jump at the cables at the battery and it cranks good, I'd suspect you have a bad connection at the battery or maybe, a battery cable that is frayed or corroded inside the insulation of the battery cable. |
Yes, it does have considerable compression.
All cables and connections are good. I kind of think I'm looking at a broken compression release [ if it has one ] or an internal starter problem. |
