Old 08-15-2013, 01:12 AM
brad.bristle99's Avatar
brad.bristle99 brad.bristle99 is offline
Default Couple questions
Is creeper drive slower that the regular gears or is it half gears. Is creeper something you can switch will you are driveing or do you have to have the clutch pushed in.
Old 08-15-2013, 08:18 AM
cubby102's Avatar
cubby102 cubby102 is offline
It more ornless just splits the gears I'm not sure of the exact ratio but third gear in low is slower then first in high. And yess you want to come to a complete stop before shifting
1872 - 60"haban 54" power angle haban blade
'63 Original - restoration project
582 -tiller
147 - leaf duty with bagger.
1811 - Ditch mower
800 - have it just cuz its a 800
Old 08-16-2013, 09:08 PM
Tim.E's Avatar
Tim.E Tim.E is offline
I don't own a creeper,but the way I understand it,when you put the creeper in low,it gives you a 4:1 gear reduction. I would think you could only shift the creeper with the tractor stopped and the clutch pedal pushed in.
Cub Cadet 100 "Super" (red) show tractor
Cub Cadet 100 show tractor.
Cub Cadet 100 worker
Cub Cadet 106 refurbished/modified (red/white)
Cub Cadet 128 "refurbished"
Cub Cadet 1450 my dedicated mowing tractor
Tractors awaiting refurbishment:100 with fenders,128,73 with creeper and fenders,106,122,147,126 with creeper.
100 w/pan seat and 3 point hitch
Old 08-16-2013, 10:09 PM
sgirdham's Avatar
sgirdham sgirdham is offline
Yes, a creeper in low and 3rd gear is slower than 1st gear with the creeper in high. From what I have read on this forum, i have gathered that a creeper is beneficial only when you are using a tiller or snow thrower. The creeper helps you slow your ground speed and not let the tiller push the tractor. It also creates several more points that have the potential to break. This is why pullers do not use a factory creeper. MWSC has a 2 speed setup that looks pretty beefy, but I do not know if you can shift that on the fly either. I have not purchased anything from them but I hear their clutch setup is pretty stout. My guess is that most pullers just change the gear ratio in their transaxle. Hope this info helps. I am not an expert puller, just do a lot of reading online about beefing up my work tractors.
1981 IH Built 782- 44" deck
1650 dual stick
71 "121" round fender and replacement k301 carlisle tru powers and v61
Old 08-16-2013, 10:11 PM
dvogtvpe's Avatar
dvogtvpe dvogtvpe is offline
you can't shift on the fly with them. in low all speeds are slower than 1st hi. so for pulling its useless. Now Super Cub makes a hi lo gear box that drops half gears. can't shift that on the fly either.
