1882 Help with Blade
First let me apologize as I am a novice in this site. I have been reviewing the site and trying to find a few answers regarding my tractor.
I have a SGT 1882 (60" deck with leaf pick up and Haban blade) Question: My blade has the hydro power angle but the tractor does not have front hydro hook ups. Is this something you can add? and if so where? Is it a tough install? Do they make a manual angle arm for this blade (54 Haban)? Thank you for any information you can lend. This is a extremely useful site. |
You can add a hydraulic dual outlet up front, but you will have to find and purchase a dual lever valve setup to replace the single lever you have now. Also you will have to buy or have some hoses and connections made to run along the frame to the front and mount them. All in all, it might be better to find a manual 54" blade that you can adjust by hand and sell the hydraulic blade. I know xtrememotorworks.com has a 42", 54", and a 60" blade that you could mount to your under carriage that you have with the hyrdaulic blade for @ $450. Or you can sell the Super, and buy another super that has the front outlets already there. Sorry I'm not much more help. Someone else may have a better idea.
DWayne 1973: 128, ag tires, 3pt. lift, spring assist, lights, 42" Deck 10" moldboard plow 2016 XT1 42" deck 18HP |
Actually the 'cyclops' tractors are different in that the valve bodies are stackable, so you need another single hydraulic valve (easy to find) and a bunch of other stuff that may or may not be easy to find. The service manual for the 1882 should detail the process, which would give you an idea of what is needed.
Ah, didn't know those were stacked. Something else I have learned.
Thank you both for the information.
102-P Narrow tires no creeper--42inch deck and IH blade. 102-D Wide tires,creeper,headlights--42inch deck and CW36 snow thrower. 1997-2086 Super with 3 point hitch and all the bells and whistles. 1961-PTE-"O", needs lots of work. 2072-Repowered with a ch18, Woods tractor. 149 with my Dad. 44" deck and QA36A. #9-70 with weights and sleeve hitch. #10-149 with a 38inch deck. 2015 Kubota BX 2670. |
hi guys
i have an 1882 with all the hydraulics and levers but im trying to find a 4way plow set up any ideas. |
The front hyd setup for the Cyclops tractors is a hard find valves. They went NLA last year. Used ones are out there, and the tractors with them on are few and far between, so parts are not to easy to find. When I wanted to install a setup, the parts at that time, which was only about half was $750.00
