Old 02-25-2021, 03:52 AM
sofasurfer sofasurfer is offline
Default LTX1050VT with Kohler 24hp leaks oil
There is a puddle of oil on top of the drive pulley at the bottom of the engine. Can I assume that this is the lower crank seal? Could it be from another source? I don't think this would indicate bad rings or anything like that. Just a good old drippy leak falling out of the engine onto the pulley.
Is this a relatively easy repair? Not sure but the parts diagram seems to show a seal that is or the outside of the oil pan. Hmmmm.
One other question.
Is the LTX1050VT what they call the 1000 series?
Old 02-25-2021, 07:51 AM
Inactive Member
As far as the oil leak, I always find it best to spend the time to trace it down and positively know where it is coming from. Better than "shot gunning" the engine with parts.
Yes, that model is considered a 1000 series tractor.
Old 02-26-2021, 03:55 AM
Bryan S Bryan S is offline
What R said. I'll add, and how can we know where the oil is leaking from,
when we are here, and your tractor is there.
It's a liquid. It can drip and travel quite a long distance,
say like down a frame rail and come out really far away
from where it dripped.
The Cub Pack. 70, 100 (creeper), 104, 122 (2), 1250, 1810, 1863, 2182, LTX 1050, SLTX 1050, SLT 1550, SLT 1554, Snow Chuckers 450, 451, 826T, 1030E, 2 plow blades. always looking for "just one more"
Old 02-27-2021, 08:57 AM
B440? B440? is offline
Pull the cooling shroud cover off and look for the highest location where there is oil residue.
Most common leaks are near the valve covers. Could also be near the oil fill dipstick if it has one.
If the oil residue is lower, then it could be the sump gasket.
Actually, you should also check the oil drain. A lot of times it is very loose from the factory. Might need to tighten it with a wrench.
Old 02-27-2021, 09:28 AM
ironman's Avatar
ironman ironman is online now
LTX1050VT = Briggs Engine
LTX1050KH = Kohler Engine
Is this a replacement engine?
