Model # label location??
Help! I bought a new Cub TankSZ 60KW. I have looked all over, up , under, inside outside that mower and cannot find the Model/Serial# tag. Called the dealer, he said the model number is "SZ60KW."..duh. I cannot register it for warranty without these numbers. I paid a chunk of change for this zero turn, and want to protect that investment.
Anybody have any ideas? I looked at the official Cub site, the tag is supposed to be under the seat...the only tag under the seat is the tag for the seat , model and serial.... |
Model and serial number is prolly on the receipt you got from the dealer.
You could also take it back where you got it and ask them to locate the tag for you.
If they can't find it, then I would ask to exchange it for a machine that does have the tag or for a refund.
From the looks of it a 2016 is Model 17BSDGHD010 Is that what is under the seat? I doubt the seat has it's own SN See here http://www.cubcadet.com/equipment/cu...Serial_No.html Quote:
-Jason Cub Cadets: 1200 | 149 | 1650 | 122 | Z-Force S 54 Implements: QA42A | Push Blades | #2 Tiller | Rear Blade | 223A Utility Trailer | And a few mower decks Gravelys 5260 | CI Walk-behind (Project) And a couple of Subarus |
This is a Commercial Zero Turn SZ60 with a 27 hp KW engine. My sales receipt is pink, and handwritten, it is a cover all receipt for Case, Cub, Toro . My next step would be to call Cub and go through a lengthy process to arrive at the correct numbers. Thanks for all of the input, it is appreciated. |
Dani
My guess is that if the dealer can't give you the info your best bet is to call Cub. They should be able to track it with the engine serial number. They also should have records of what machines went to your dealer. Good luck and keep us posted.
Very interesting. I'm curious to see what you find out too. You'd think it would be right where they say it is.
Perhaps the label got left off.. Or maybe the seat was damaged during transport and they didn't move the tag to the new one.
Thanks for the input. I saw a video on YouTube that showed the tag on a different model zero turn under the deck cover..once I figure out how to lift it up, I will look there.
Beyond that, calling Cub tech for help. Thanks for your interest, and I will keep you posted.Who knows, maybe it will help someone else someday?? |
Here's the scoop...my model/serial tag was under the deck cover. So glad I found the YouTube video .
Hope this info helps others. Attached are the pics of close up label and long shot of location. Thanks again for all of the input! |
You get the detective award of the day!
