Old 12-26-2020, 04:15 PM
romans romans is offline
Default Best of both worlds?
I had a old wheel horse with a plow that I used to plow snow with. Everything was mechanical but you could also change the angle with out leaving your seat.
So this past year I incidentally became a cub collector of sorts and I used my 782 with a 42in plow for snow just yesterday for the first time. I am really digging the hydraulic lift. However, as you all know, you have to get off the tractor to change angle. I learned yesterday that if I had to trade one for the other I am glad for the hyd lift as I raise and lower the blade a whole lot more than angling the blade.
I was curious what you guys have done to get around this shy of hydraulics? The 782 is only single valve. Looking for ideas on how to accomplish the best of both worlds. Pics are great by the way Thanks,
Old 12-26-2020, 08:27 PM
IHCubCadet147's Avatar
Check this out: https://www.onlycubcadets.net/forum/...ad.php?t=56111
Old 12-27-2020, 07:37 AM
Inactive Member
The 782 could be updated to a dual spool valve, run lines, and couplers, to the front of the tractor. Then you could use a Hydraulic Angle Kit.
Old 12-27-2020, 09:30 AM
IHinIN IHinIN is offline
The blade angle mechanism I built works great but I’ve since added front hydraulic remotes to my 129 so I no longer use the mechanism.
File Type: jpg 83539FA3-A6EB-4166-B5F9-D70FF8CC343E.jpg (27.8 KB, 268 views)
Old 12-27-2020, 08:14 PM
I do have an extra single valve from a 149 at my disposal. Would there be any promise in making that work for the hydraulic option? I am fairly hydraulic dumb, I know I really like hydraulics when they do what they are suppose to but it gets shaky quick after that. I dont even know what the valve looks like yet, sad state of affairs around here, let me tell ya.
With plow season upon me, I probably wouldnt do anything until after the snow is gone anyways... unless I could get motivated on my "other" plow endeavor involving a 1882 and a haban (no hydraulics) that was thrown in on a leaf vac deal. Now that is one of those "did that just happen?" deals that I completely stumbled into.
Old 12-27-2020, 08:23 PM
Inactive Member
Absolutely. There have been people that have had three Spool Valves on a Cub Cadet.
Old 12-27-2020, 09:02 PM
Well... since I am closer than I thought to a solution what is this hydraulic angle kit that you speak of???
Old 12-27-2020, 09:44 PM
I added a 2 spool valve and plumbed it inline with the factory lift valve. My 129 is actually a 149 with a 12hp K301. That’s why it has the factory hydraulic lift. One spool goes to front quick connects and the other spool goes to rear quick connects.
File Type: jpg 2D7BBFA3-43F4-4EB6-8883-59D2C26989AC.jpg (27.5 KB, 246 views)
Old 12-28-2020, 06:29 AM
Inactive Member
Here is a picture of the (then) Hydraulic Angle Kit.
Old 12-28-2020, 09:12 AM
if you look at your "spool valve" it is attached to your steering column below the dash and it has hydraulic lines attached to it.
It has one "spool" (where the actuating lever linkage is attached)
A dual spool has 2 spools or a double valve as it is sometimes called.
if equipped from the factory, one would have 2 levers on the dash instead of 1.
simple really.
