Go Back   Only Cub Cadets > Cub Cadets > Cub Cadet Engines
Old 11-18-2014, 05:40 PM
IH_147's Avatar
IH_147 IH_147 is offline
Default K-301 RPM's
hey guys my 12 horse k301 revs like in the one on the carb the governer make and it goes vrr vrr vrr so i rebuilt the carb and cleaned it and reset the internal governer to factory then reset points and its still about the same im really stumped any ideas. i was gonna take the carb apart and put it in a cleaning solution so i hope it helps
100,122,126, 126, 126, 147,147,800,127, 982, 1210, farmall 300, farmall 560 diesel
Old 11-18-2014, 05:46 PM
What?
Old 11-18-2014, 06:23 PM
dvogtvpe's Avatar
dvogtvpe dvogtvpe is offline
are you trying to say the engine surges?
Old 11-18-2014, 06:39 PM
IH_147's Avatar
hahaha sorry guys yes it surges i guess ive got my own language ( it seems i only understand it) ha
Old 11-18-2014, 07:08 PM
dvogtvpe's Avatar
when you rebuilt the carb did you remove the emulsion tube to clean it out? did you clean your sediment bowl? it the throttle shaft loose in the carb?
Old 11-18-2014, 11:28 PM
IH_147's Avatar
throttle shaft is not loose, i cleaned sediment bowl and the what tube were is it
Old 11-18-2014, 11:31 PM
The emulsion tube. It screws in from the bottom where the bowl bolts on. Look up in the hole, you'll see a slotted (like for a screwdriver) brass piece with a hole in it. Emulsion tube.
Old 11-19-2014, 07:33 AM
IH_147's Avatar
so i should remove that jonathon
Old 11-19-2014, 08:23 AM
dvogtvpe's Avatar
yes, that needs to come out to clean the carb decent.
Old 11-20-2014, 07:02 PM
IH_147's Avatar
well guys I did what you said and still surges
